Product Reviews | Trail Reviews | Classifieds | Hotlinks | Forums | Races & Events | Gallery | Hot Deals
Home | Forums
MountainBikeReview.com's Forum Archives - Brake Time
Archive Home >> Brake Time(1 2 3 4 5 6 7 8 )
hayes lever pumps out on downhill ride????(5 posts)
hayes lever pumps out on downhill ride????13
Sep 21, 2001 12:52 PM
i'm sure i dont have air in my system
whenever i'm on the brakes on a downhill my lever starts to pumpout(lever reach suddenly extends from normal)
i understand that hayes has a reservoir for expanding fluid so this should not happen?
any idea whats causing this?
by the way its on my rear brake thats the problem my front seems to be okay
thanks for any info
Too much fluid in resevoir.Robert.
Sep 21, 2001 2:57 PM
If the system has too much fluid thre will be less space for expansion.
re: hayes lever pumps out on downhill ride????Dougal
Sep 21, 2001 3:14 PM
Yep too much fluid.
Bleed it again but push the pistons back into the caliper when you do.
Dougal.8m.com
can i just open the master cylinder bleeder & push out the pads?13
Sep 22, 2001 4:02 PM
without bleeding the whole system,i dont know how to and i dont want to mess up my system,
if ever i do try to bleed it whats the difference between dot 3&4
thnks
Yes, if you're careful.Dougal
Sep 23, 2001 12:27 AM
Yes if you're careful you can do it this way. Take the pads out first to make sure you don't get any fluid on them. You may need two people to ensure no air gets in.
Dougal.8m.com
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a division of E-centives, Inc.
