|  Can you reduce travel on a 2001 Z-1 MCR ? | SCHeck Dec 20, 2001 1:48 PM | | Stock is 130mm - can this be reduced to 100-110mm travel without the purchase of aftermarket parts?
Thanks. |
|  you need a spring kit.... | zedro Dec 20, 2001 3:16 PM | | 2 main springs, 2 negative springs. Your LBS can order the kit. |
|  Nope, like Zed says... | Squash Dec 21, 2001 4:38 AM | | You have to buy the spring kit. The only 01 Zocch that the travel could be increased or decreased without the purchase of a spring kit was the 01 Z3.
Good Dirt |
|  Thanks for your responses (nm) | SCHeck Dec 21, 2001 4:59 AM | | ¨ |
